ARB Bushes
GrahamS
I know there are lots of threads on this but they're contradicting what I've found.
This is what's on Kam racing for my 182 which is a non-cup.
Clio Ph2 2.0 16v RS-182:
  • Outer mount - 22mm - PFF60-207-22
  • Inner mount - 25mm - PFF60-202-25
I've checked the OEM renault part number on the bush 7700784171 is a 21mm bush. Just want to confirm what OEM type bush I should really be getting and if I need to find a 22mm. Not looking to powerflex. I assume the inside is a 25mm.
Strangely,my non cup 172 is listed as 23mm outer,but your 182 as 22mm.I would have expected to be the other way round.
7700784171 cheap as chips.http://www.eurocarcare.net/front-suspension/ecc7700784171-anti-roll-bar-bush-outer.html
Headlights were A1 by the way,thanks.
Yeah weird isn't it. I measured the car yesterday and it came up as 24mm on the outside so I just can't see any logic here!
Glad they were good! their light output is certainly better than my new 182 ha.
I found this from an old thread on here from 2011.I am not saying it is accurate though,as it matches Powerflex application exactly.
On the other hand,if it was inaccurate,I would have thought both would have been corrected by now.
I can only speculate that perhaps your 22mm is waisted.
In case you need to know sizes for ordering:(original 2011 post)
Clio Ph1 2.0 16v RS-172: Outer mount - 22mm, Inner mount - 25mm
Clio Ph2 2.0 16v RS-172: Outer mount - 23mm, Inner mount - 25mm
Clio Ph2 2.0 16v RS-182: Outer mount - 22mm, Inner mount - 25mm
Clio 2.0 16v RS (172 & 182) Cup / Cup pack models: Outer mount - 23mm, Inner mount - 25mm.
http://www.kamracing.co.uk/car-tuni...-renault-clio-mk2-2-0-rs-172-182-phase-2.html
I checked with my local Renault parts specialist,http://www.rrautos.co.uk/,who is hooked up to Renault and can order direct from them for next day,and my std 172 OE outer bushes are also 7700 7841 171.
In case you need to know sizes for ordering:worried:original 2011 post)
Hi Steve how's life in Luton
I ordered them from ECP in the end, they're listed as 24mm but are the right part number so going to take the gamble at £4 each.
All 172 ph2,172 cup,182 & 182 cup packed cars have the same anti roll bar,pt no 8200 104 120.
Not sure why Powerflex list 22mm for yours.
I used EU02LND (PH2 172),WG52AVR(172 CUP),LY54FKD(182) & YC55UKZ(182 CUP) for part numbering.
I`m sure you will be fine with 7700 7841 171.
