ARB Info
Car  Vauxhall Corsa
Does rear ARB (Whiteline or Pro-Motorsport) replace the standard OEM rear ARB, or is it fitted in addition to?
Secondly is it worth also replacing the OEM rear ARB bushes with Powerflex ones when fitting an uprated ARB?
Ben
The Whiteline is cheaper and a fit and forget item. The way it mounts gives no adjustment - I would fit this to a road car primarily.
The PMS mounts differently and is adjustable. Its more expensive but if you are running a track car I wouldnt fit anything else.
You can buy both here
https://www.kamracing.co.uk/car-tun...duct_category_sub=4314&product_car_model_new=
The original car effectively uses a twist beam for the rear suspension, the stiffness of the beam effectively acting like an ARB.
