Hi All,
I'm having a problem fitting inner arb bushes. i first bought some aftermarket bushes, had issues installing so bought oem. I got the exact same part number as the bushes that came out ,7700847383 , and i cannot get the clamp back on that goes around the bushing.
I've attempted to follow the guide on the forums, https://www.cliosport.net/threads/mk2-rs-arb-bush-replacement-guide-pic-heavy.817150/, but it doesn't make it sound as difficult as I've been experiencing it. i've been using a g clamp + vice grips but it gets to a point where i cannot wind the g clamp anymore and it's still about 5-6mm away from hitting the mounting point.
The arb was quite rusted so after numerous attempts at putting the arb clamps on i've removed, wire wheeled and painted the arb incase it was a fitment issue due to rust. while the arb is off the car I've trial fitted the bushing and I've noticed there is a massive gap where the bushing splits which would explain why i'm having such troubles fitting it as I could not see a gap in the powerflex bushes used in the guide on the forum which makes me think it's not the right size? the part i've bought is the 25mm inner diameter , having measure it the hole measures at 24mm.
help
i didn't get a pic of the side view but I'll post that when i'm home later to show the gap.
help
