Are these the right wheel bolts?
Jekyll
M12 x 1.5 (pitch) x 26mm (thread length) with a 60 degree taper head is the standard size for 1*2's.
Obviously if you run a certain sized wheel spacer then add the sized spacer on top of the above thread length. (Rear hub spacers take standard wheel bolt size)
Jekyll
  dan's cast offs.
Been thinking this, they hard to fit?
piece of cake, wheels off, clean threads out, loctite on the stud and wind it in and that's pretty much it. avoid the cheapy ones though as they don't have a shoulder on the thread so can be wound to far in to the hub.
  dan's cast offs.
