ARP bolts
Sj1782
Car  Audi s3 8p
What’s a rough priced I’d be likely to pay for a set of arp bolts to be fitted?
get oil pump relief valve modified at the same time. also check bottom end bearings.
Don’t want to sound thick but what would the benefit be for the relief valve modified?
should hopefully stop the bottom end shitting itself :tonguewink:
they apparently don't hold pressure well at high revs for long period of time. seen a couple of bottom ends go recently, including my phase 1.
Ah I see! Worth it then I’d say! I Was looking into the bolts as I’ve had the 197 cams fitted nearly a year ago and it gets a lot of stick! Was hoping to replace with arps as a precaution and it’s out of my skill set [emoji23]
