Audio Help
Dip
Car  04 Clio 16V Dynamique
Right, decided to change the Standard HU to an Alpine 9855, which I've already got from the previous car. I know amping the comps is the best thing to do. I've also got a Directed A1004 but I really cant be dealing with wiring the Clio up, and I need every inch of boot space!
I want to run upgraded comps from the Alpine without amping, what would people recommend front comps and what the rears take? Could someone please tell me sizes front and rear too please.
Thanks.
Spend up to 200 for both, had a set of Infinity Kappa's before wouldnt mind them again but Im willing to consider something else. Just want the sound quality without the amp. Is there enough space back there for larger sized magnets?
I've just put some Rainbow 130mm components in mine, fit perfectly!...I've also found a way to get some decent speaker wire to the doors, I'll write up a tutorial at some point and take some pictures!
If you want to amp them you could always stick a decent amp under one of the seats!
Would be usefull, gota finish building the box for my sub and il then be wiring it all in, havent yet looked for a way to get into the doors so this might make things eaiser if you could.
