auto electrician needed
  Clio 172
I have air/fuel mix and oil pressure dials waiting to mount in my car. The wires are confusing though.
air fuel mix has 3: to 5amp fuse on ignition/ battery / oxygen sensor
but in the instructions it shows that there may be an optional 4th wire to connect to the 12v supply
oil pressure has 2: 12v supply / earth
So, I don't know if i have the wrong airfuel dial. I guess the 12v supply is the circuit for the dash lights, if so, where is the best place to tap in to it?
the oil pressure sensor is also in imperial size. Will i need to change this as the Renault is metric?
Cheers in advance
PS the gauges are from Auto Meter
