Auto Headlights on 172
Car  Clio 172 Monaco Blue 7/46
Hi All,
I have a 52reg 172 - havent had any mechanical problems yet (although have been thrashing the tits off it recently so it may bite me in the arse soon)
LAst night i started the car and the auto headlights didnt come on - they work as normal when manually turning them on though, has anyone else had this problem or know what it might be, i havent checked the fuses yet, im not sure if it could be down to that?!?!
I've got a Gold level warranty though with Warranty Direct so should be all good if i need to take it in somewhere...
Cheers,
Marcus
its possible its been reset, try putting key in ignition and turning that feature back on. Thinks it turn lights off and then on twice. You should hear a beep.
cheers, i'll try that when i get back to the car after playing sardines on the tubes later.
Thanks to 'GTRUK' as this worked first time - just turned the key to last position before starting the engine, think its called auxillary position and then turned the lights on and off twice and got a beep - now they're working fine. :clap:
