Autoglym Paint Renovator JUST MADE IT WORSE
  astra gsi/cliosport 172
My bonnets pretty bad on my black 172 its swirled and has some sort of scratch like haze and mabye oxdised so thot i would try the product above and taped around one of the areas that needed doing and once i buffed it off and had a look with a light its made it a lot worse like its cut right in and made even more swirls any ideas of how to get rid by of by hand
cheers chris
  STEALTH RAIDER
I think you've just been putting to much pressure on the area Chris, or rubbing too hard when taking the residue off. If you want to get rid of hazing permanently then i suggest you get a decent polish with a low-medium cut. You used a proper hand pad for the job? Lew
  Golf GT & A4 Avant
as said sounds like you've gone a bit too far wit the abrasive. have another go but with a lighter pad and lighter action so that you're not getting the degree of cut. In essence as you would when sanding down, start with something abrasive then slowly work down to something lighter.
