AUTOMATIC LIGHTS !!!!!
Car  182 ff
Hi there people got a little problem and was wondering if anyone has the solution for it
my auto lights dont work no more on my 182 is this controlled by a fuse or relay ?? anyone else had this happen
thanks
mark
Check that the auto feature is activated - with the key in the ignition with all the dash lights on, turn your sidelights on and off, then repeat. It should beep at you to tell you it's done ok. Then start the car and cover the sensor to double check.
This happened to a guy I work with ... I think it turned out to be a relay under the passenger footwell somewhere ... His girlfriend had yanked it out with her feet! Ooops!
