This thread is here for members of the product test panel to submit reviews, pictures and discuss our snow foam, Avalanche.
An overview of Avalanche:
This Citrus Power infused foaming pre-wash solution is the perfect product to assist you in those winter months to loosen and remove road grime prior to contact washing, doing most of the work for you.
Avalanche was developed to fill a gap in the market, whilst many snow foams proclaim to remove dirt and grime prior to contact washing, many produce a great looking thick foam but don’t really deliver in terms of cleaning power and shedding road grime from the exterior prior to washing. We wanted to turn this on its head with Avalanche and that’s why we turned to what we know works and included our Citrus Power formula that has a proven track record as an effective LSP safe pre cleaner, to give a snow foam those same qualities.
Why start your wash routine with Avalanche?
Often over looked the pre-wash can be one of the most important stages in your wash routine to achieve a perfect swirl free wash. The use of Avalanche snow foam during your pre-wash will save you a lot of time and hassle as you simply spray on and let it work its magic. Avalanche’s citrus infused formula quickly sets to work removing any loose road grime sitting on your paintwork.
Using Avalanche:
Using Avalanche starts with diluting it down into your snow foam lance bottle. By rule we recommend an inch of Avalanche in the bottom of a one litre foam bottle and then top up with fresh warm water, and then a quick shake once the lid is on to ensure your Avalanche is correctly mixed.
Once mixed up its time to foam. Cover your vehicle from top to bottom with Avalanche ensuring that you foam all of those cracks and crevasses where road grime can often be found hiding. At this time its also useful to give your wheels and wheel arches a blast with Avalanche. Avalanche is the perfect cleaner for your wheels and arches if they only have light grime and are already wearing a coat of Mint Rims wheel wax.
Although Avalanche is not the thickest snow foam on the market it will cling on to your paintwork with ease releasing any light contamination such as road grime or dust that your vehicle has picked up since its last wash. In fact during the summer months some even use Avalanche on its own as a touchless wash to remove light road dust, by simply spraying on, allowing to dwell and then rinsing clean. However if your vehicle has anything more than light dust its a must to bring out the two buckets and give your vehicle a safe pH neutral wash using Lather car shampoo.
Another ace up Avalanche’s sleeve is engine bay cleaning…
Avalanche makes for a great engine bay cleaner on modern cars and motor bikes when mixed with Verso all purpose cleaner. The mixture of Avalanche and Verso insures a long dwell time and strong cleaning capabilities on modern engine bays. Simply foam your bay down ensuring you do not over saturate delicate areas such as your alternator. Allow this mixture to dwell for up to five minutes, however ensure that Avalanche does not dry out. If necessary give any heavily contaminated areas a quick brush over with our Hog Hair detailing brushes and then rinse away the grime ready for a layer of Dressle for that factory fresh look.
We look forward to hearing and seeing your experiences with Avalanche and results it leaves for you…
Happy detailing,
The AF Team
Using Avalanche:
Happy detailing,
The AF Team
