Back box question
Car  182
Hi, I'm in desperate need of a backbox no one on here seems to have one. So been having a look around and seen this on ebay http://tinyurl.com/ckdzza2, looks the same shape as the standard phase 1, I presume its a pattern part, does anyone have any experience of these, likely to last 10 minutes and then go ka-put?
Also, bought a cat today off a member, didn't realise it was just bolt on, are there any gaskets that need to be used ot can i just bolt the cat straight onto the pipes?
Cheers, Mike.
Cat needs a gasket on the rear flange and a manifold-cat fitting kit for the connection to the manifold.
Yeah found the cat to manifold kit, is it easy enough to fix? As in obvious, I really am a mechanical r****d.
Do you have a link to the gasket for the rear flange? Can't see anything.
Cheers.
It's just a metallic gasket. Get one from your nearest dealership or use high-temp silicone. Fitting the cat on a ph1/ph2 172 isn't the nicest job tbh. Access is pretty limited.
