Badges
If I want to have the Renault badge on the front and badges on the rear sprayed, how do I go about removing them?
I'm assuming the badge on the front will be a little bit of a lenghty process?
The ones on the rear... are they stuck on. If so, do they also have guide pins behind?
Only the Clio badge on the rear has pins and holes behind it. Renault Sport are just stuck on.
presume you mean the front diamond? if so, it can be removed without taking th bumper off but its a pain and likely to cause scratching etc. so take the bumper off and its held on to the plastic back ground by a couple of clips.
the rear diamond is glued to the boot lock as i found out, so you would have to mask up the surrounding area.
as rich has stated on the rest of the badges.
jamie
