as above, but it's normally somewhere between 5 and 7 kg/h, and you need to be watching what the ecu is doing with idle control at the same time to make sure the ignition timing at idle sits somewhere sensible normally between 0 and 10 degrees. Engines vary though, and so do peoples opinions on what's the right setting. too retarded at idle and you'll overheat in traffic
