BB performance Tuning
a quick question
ne1 had there cambelt done there, if so do they do it same day, and on there site it says 157 fitted is it really that price lol
That is just for the cambelt, if you want the full kit fitted - with tensioner and idler pulleys too- it comes in about £340 with the VAT
Yeah had mine done there last year. They found the water pump needed doing too and thats what took them so long. Didnt help me not having thelocking wheelnut key athey wanted to take the wheel off and arch inner liner for better access.
Would recommend their servicing of valvers. Had their chip fitted at same time which makes the 16v more drivable but now this isnt much cheaper than a unichip or other type of programmable chip. Wish I had got the programmable one now.
Whilst there I would get some magnecor blue spark plug leads. Then you can change the spark plugs yourself and check/change the dizzy cap and rotor arm as recently found mine shot on a 96 N reg car. Probably the OE ones. Little jobs like that are easy and help make sure you are getting the most out of the car.
Fuel system cleaner and fuel filter change also worth doing if not known when last done.
CAMBELT
£20.00
This item is available fully fitted at £157.50
Genuine replacements at a fraction of the cost, Firstly the cambelt should be changed every 72,000 miles or sooner if performance upgrades have been carried out. If the cambelt breaks then internal engine damage will occur, so it can be very costly. Whining noises usually indicate worn bearings on either the tensioner or idler, a replacement is recommended.
(**WILLIAMS COMPATIBLE**)
sorry but to me that means they fit it for 157.50 or am i just thik as down nails
I cant really comment on the price as mine was done as part of a full service, I cannot fault these chaps on there work mine was in for a couple of days for full service, cambelt low temp fan switch.
Best way to find out how long will to give them a call direct.
Clare
that price will be plus vat though mate and you will want to change the pully and tensioner and that will make it closer to £300 with the vat on.
Paul
rang them this morning booked in 4 friday 26th.
he said 157 corse the vat then whatever they can strip me up 4 to get money back LOL nah sure will b fine,
