Been to see a 172
Car  Between cars at the mo..
Here's the details
RENAULT Clio 2.0 16v Renaultsport 172 , 2001 51 Reg , 55,000 miles, Metallic Red. Full service history, Leather upholstery, Sports seats, Climate Control, Air conditioning, Radio/CD, Alarm, Central Door Locking, Power-Assisted Steering, Alloy wheels, Remote Central Locking, Electric mirrors, ABS, Electric windows. £5,695
Seems in good nick. Needs a service tho and i noticed the rubber insert on the steering wheel (right hand) needs replacing and its been completely torn.
Does anyone know how much a 55k service (and what maybe involved?) is likely to be and also a new steering wheel or whatever it takes to replace that insert?
I will say tho i did have a grin on my face whilst driving:cool:
Is it at a dealer? If not i wouldn't pay anymore than around £4900 service is £155ish
The car isn't from a main dealer.
Sorry i just rang the local Renault Dealership and had heart failure:D
£185.40 oil/filter, pollen filter, air filter
£640 cambelt @ 72K:eek::eek::S
Apparently the steering wheel would need to be replaced according to Renault Parts and thats £320 nevermind fitting:eek:
Don't go to renault!!!! cambelt is about £400 from an good independant garage.
Cambelt is 5 years or 72k, and thats 5 years old.
yep cambelt is the biggy, use it to get cash off. Seems overpriced anyway tbh. I've seen 53/04 plates with lowish miles for around 6.5k
Personally i wouldn't want to have a car which has missed the cambelt service unless the last service was late too. Was the auxillary belt done at 36k?
Bear in mind that it is coming up for the next minor service (60k). I think there are plenty to around to choose a better example.
As said previously my 172 51 plate with 28K miles cost £5000, private. It had already been serviced before i brought it. I've had the cambelt changed along with both the cam pulleys for £600.
Steer clear of renault for servicing!
mm perhaps i'll stay clear of it then... shame really :| i might check my local garage to see how much the servicing would cost. I'll ring the garage up and get them to check when and what stuff has been done it was all serviced by renault but there where no receipts or anything :|
Things is i want a 172FF as it has all the features i want compared to the cup version. I'll be ready to buy hopefully by next weekend;)
ok thankfully the belts have just been done so it just needs a minor sevice.
Does anyone have a service schedule for a clio 172?
and the steering wheel...
Fitments not a long job.
Thats abit drastic there not cheap but if you've even seen the messes other garages have done on Renault you'll realise why they are worth the money often.
IF you need belts chnaging Renault or a specialst Renault dealership onlyto many mistakes have been done not to.
Check it realy has been done a stamp in the book mean nothing. People know new cambelts sell cars particult if the buyer knows the cost if it snaps 5k down the line you cannot go back and complain.
172/182
Normal servicing is done ever 12k or 2 yrs there is a 1 month/1k tolerance so you can have it done up to 25month or 13k before any warranty implications. Beyond this time/warranty period you maybe asked by Renault for a % payment from yourself for warranty work depending upon how much later you had the service done. However they can only really ask if having the service done at the right time would have spotted the issue. The servicing period used to be 12k/1 yr some dealers haven’t changed there stickers or aware of the new rule which applied to the Renault Sort cars now
What needs to be done normally.
The service schedule is quite complex so instead of being called 12k etc I’ll change them to
12k A
24k A
36k A and B
48k A
60k A
72k A, B and C
84k A
96k A
108k A and B
120 A
Hopefully you get the idea. At 72k you need both A, B and C doing. When you do the work / book it in you ask for the service by mileage though.
If you don’t do 12k ever 2 yrs then the car needs to be serviced ever 2yrs to the same specification as if you had done that mileage.
An “A” service consists of
Change oil (for a 5/40 oil this is important to check some dealers use 10/40 as per normal Clio’s)
Change oil filter
Change air filter
Change passenger compartment filter (if appropriate)
Check bodywork for rust etc (this is part of the Renault anticorrosion check)
Check brakes for wear, failing seals, fluid level (the reservoir on the 172/182 is at the back of the engine on the driver’s side on the bulkhead. You need to remove the engine cover if fitted to see if often as it is in an annoying place)
Check power steering fluid level/pipes
Check exhaust
Check condition of the rubber gaiters on the steering rack
Check the coolant level (big tank attached to the back of the engine bay on the passenger’s side of the car. Top up etc as appropriate so the level is between the minimum and maximum. Make sure you do this when the engines coolant is cold as the system is highly pressurised (1.2 bar and hot) so it can hurt you if you try removing the cap when it’s hot. Also fluid level changed when it’s hot.
Front and rear windscreen wiper check. Condition etc.
Tyres check for uneven wear and pressures (spare should be also check).
Check front and rear shock absorbers are correctly fixed no leaks etc.
Check bulbs work (brakes/indicators etc)
Check battery charge state.
Check all windows/mirrors for cracks etc.
Computer check of any errors logged in the ECU etc.
Some dealers will check other things i.e. tyre wear depth and top up washer fluid these should be a normal check anyway though as an owner.
Expect to pay between £120 and £150 depends where you are in the country. Shouldn’t take more than half a day but dealers ask for it all day so they can have work all day for the mechanics.
A “B” service consists of
The auxiliary belt (known as the AUX belt) being changed this is about £100 extra on top of the normal A service.
A “C” service consists of
Cam belt changed this is usually at a point where people go look at other garages as it’s a 8hr job and Renault can charge £600 or so. Unless you know the garage have changed belts on 172/182’s before don’t use them however good they are many cars have been ruined by people doing this themselves or getting a garage who don’t know the intricacies of doing the job.
Also the spark plugs are changed, the normal Renault ones are fine for 72k so no need to change them before this time. They are a good quality plug (should be at £20 a time) and there no need for any aftermarket ones.
Note for the V6 owners (Mk1 and 2)
Air filter should be changed every 36k not 12k.
Spark plugs are changed at the 48k service.
Fuel filter changed every 72k
Apart from that it’s the same as the 172/182 above.
On top of this servicing are other things that need to be done regardless of mileage
Cam belt and aux belt shouldn’t be any older than 5yrs.
Brake fluid should be changed ever 4 yrs
Central locking buttons battery changed every 2 yrs
Coolant changed every 4 yrs or 72k whichever is earlier.
Fuel filter changed ever 150k
Airbags and pretensioner system changed ever 10 years.
That’s the official lines. Personally I’d change the oil between every service (doesn’t cost much for the oil and you can do it yourself). Also change the brake fluid every 2 years or least bleed the brakes.
Renault has to ask if you want them to do any other work to your car i.e. change brake pads. Personally I wouldn’t get them to do any as you can change pads in 40 minutes and buy them from Renault for £40ish. Renault will want £40 to fit them so might as well save some money.
