Best engine cleaner...
R-Sport.
  Mint 1*2's for sale-
For an engine with ground in dirt & grime-
I have & usually use AG Engine cleaner, however Im not sure its up to the task -
Is there any better / stronger products out there to agitate on initial spray-
thanks
Steve :)
  Clio 182 BG
At our Renault garage we have the original Wheel cleaner (the red one), best way to clean everything like rims engine exhaust system etc
As above Steve, Daisy is a cheap All Purpose Cleaner.
When you say EAMC isn't going to cut it, what are you trying to get rid of? Grease? Tar? Or just baked on muck?
Ali
  V6, Trackhawk, GTS
APC will not remove tough grease! No way Hozayyyy!!
You need something alot stronger, like bilt hamber surfex HD! I personally can't see past the stuff.
Ali
  V6, Trackhawk, GTS
Ha! Never tried it. The surfex is good tho, i use it on the inside of the wheels mainly, I think the boots are perishes on the clio so i get loads of grease in there.
Had that twice in the last few details, CS owners with leaking or knackered boots :( Bye bye Megs brush.
  ITB'd MK1
wont be perished. The clips will be broken. Easy fix if you sort it now, very expensive if you leave it
