best setup from what i have
Car  FF 182 Sport
ok, i have standard 172 cabasse setup speakers - front and rear, some cheapo vibe 6x9s in my shelf, 2 sets of fli 13cm components 225w, a fusion 800w 4 channel amp, a vibe blackair 12" amped single sub, a twin 2000w 12" fli amped sub box and some rockford fosgate woffers 13cm from a component set....
currently imn on std front speakers and 6x9s in my shelf running off alpine 60wx4 headunit
my question is - given the options whats the best setup in a clio
my thoughts components running off ampf+r - maybe the 12" vibe in the boot too - but are components good enough to listen to on there own or are 6x9s better
im confused
Front components running off an amp and a sub in the boot bridged off the rear channels or off its own mono amp.
Rear speakers mess with the sound stage, and 6x9's are pointless if youve got a sub anyway
now thinking maybe 4 tweeters off the headunit outputs, front and rear components off the 800w amp and then the twin 12" in the boot lol
Chhhhhhhaaaaaav tastic!
yeah thought that to be honest
both my subs have inbuilt amps so not really an issue -
can i loop power from one amp to the other? got a decent guage wire...
also can components be hidden where current ones are in the dash or is that too fiddly for wiring etc?
Stop over complicating things, the simplest setups often sound better.
Don't mix subs itl sound crap.
Yes you can use the same power cable however it needs splitting with a distribution block, however the main cable needs to be thick enough to cope with the load from both amps.
Head over to talk audio they'll give you some advice, but will more than likley say what I've already said.
Wasn't gonna mix subs lol, just nice to get rid of shelf speakers, might look into tweeters off the STD hu gonna try just comps off the amp first...
you tried the fli components yet? if so any good? got mine lying around might fit tomorrow :)
