if you have the cash throttle body it chap, you will gain LOADS of torque
I've heard good and bad things about them, I won't say the bad things, as Its not my place to, but I want someone else to map it...
I'm in talks with angelworks to get a vems fitted.
Spot on, took mine a full day of mapping to get it right.I was told by a experienced Saxo modder, to map a standalone 100% properly would take days not a couple of hours like most tuners doo
Difference between VEMS and Omex?
Yeah, OMEX uses knock to control ignition timing. I'm running the wideband which is miles better for setting the ignition and fueling maps.
I'm sure someone will come and give an in-depth analysis though, lol.
Re. E marking- Omex are saying your insurance will be invalid if the ecu is'nt e marked but when you declare the ecu to your broker, they dont ask make and model. "I have an aftermarket ecu"......."Thats £25 exrta on your premium sir"
24000 post's :O you must live on here!
Have spoken to them, the work wasn't a year old and they still wanted money to correct a faulty map.
you what? wideband for timing adjustments? lol, I think not
Wideband is used for fueling, knock detection is used for measuring the limits of ignition advance at a load point. Without both you cannot map properly.
neither parameter have anything to do with what ECU you are using. You're confusing the fact your VEMS has wideband feedback direct into the ECU with how the ECU is mapped. Dont need self learning if you can map right to start with.
sorry, dont know who you are and no-one here can think who you are or remember speaking to you. Please give us a call, I've PM'd you. If there really was a fault or problem with the map than of course there'd be no charge
Ignition advance is part and parcel of the timing though?? Omex doesn't have wideband, so is mapped diffrently.
dude, honestly, step back. you dont need wideband built in to the ECU to use it for mapping. We have multiple wideband units for mapping cars. We also have multiple knock detection methods that are fitted to cars for mapping then removed once it's complete
i thought omex had wideband capabilities, or is that only on the 710?
I know, I never said you did! It's a difference between the ECU's though, which is what the Q was. I'm not gonna pretend I know the first thing about maping, just re-iterating what I've been told
