Best way to change the Hazard light?
I got one from Ebay. Cheap and fast!
How to change it? Do i have to remove the stereo?
Some said use flat screw driver?
I don't want any damage on the panel edge?
What is the best way?
Carefully prise the panel out above the radio then it unplugs and pushes through from the the back.
i found it easier if you just pull the stereo out a fraction...gives you more play with the wiring :)
