Best way to remove 172 gearknob?
len_beach
  E92 M3,172 track car
As above. What is the best way to remove the gearknob from both a phase 1 and 2 172. I don't want any cutting involved.
Or would it be more feasible to swap the entire stick at the pivot point?
len_beach
Mole grips.
You could remove the whole stick yep.
But the mole grips would damage at least one of the knobs?
So the shafts are interchangeable between phase 1 and phase 2 172?
Cheers Edde, you can always be relied upon.
len_beach
Cracking. Thankyou muchly Edde.
Rich, i've not had chance to call Renault yet, i'll see what I can do tomorrow.
Yep shafts can be swopped there all the same.
How do you go about doing that edde?
Firstly you need to undo the bolt which hold the gearlever to the selection bar which attaches to the gearbox.
The stick is part of a white plastic box which bolts with 4 bolts 10mm (I think) to the center of the car. From under the car undo the bolts and remove the center box cover and fiddle around and the white box bit comes out.
  106 GTi
I have not had a chance to find out anymore out yet either.
Superb, Ta.
Don't suppose you have the part number for the Stick part do you please?
  Ph 1 172
i just changed my gear knob today and i just got a pair of locking pliers and twisted it till it came off , well i say came off i mean ripped and then i took a stanley knife to if cut the rest off and then had to delicatly prize the plastic thing off by snapping it lol and then got my new one on works a treat
