Best Wheel Aligment Settings for Fast Road
Car  S4 Avant
As title, getting the alignment done on my car at the weekend, and was wondering what settings people go for in regards to toe and camber on a fast road setup.
Initial thoughts would be to go for slight toe out on the front and 1.5 - 2 degs of negative camber. Just wondering what peoples thoughts are on set ups.
-1 or 2 mm toe out in front
+1 or 0 rear
Front camber 1.5°, 2 if you don't use it on the motorway.
Rear 1°..if you can get toe and camber right using shims.
And sportlines height, not too low.
It's driver specific Dave. Just speak to the guys doing it. If they are any good they will let you go for a drive once its done. If you don't like it they will make the odd tweak here and their until you like how it handles
Mines got -1.3 camber up front
Rears got -1.2
toee parallel up front
rears factory
Drives ok used a bit on mway too and seems fine, Doesnt munch tyres either
I'd speak to someone that's set a few up (Fred/Tony Hunter come to mind) for track use.
