Big Brakes on a Williams
  Clio 172 cup
has anyone got big brakes on a williams, and still got the standard alloys on? just wandered if 285mm discs will go behind the standard speedline alloy without having to gring half an inch off the caliper?
cheers
Jim
std caliper?
you have space for a 310mm disc with appropriate callipers.....but 285 will go....
  Clio 172 cup
Yeah I had the rally design 285mm kit on my gt turbo behind 15" wheels, but the willy alloy sticks out on the inside of the rim inline with the caliper and just doesnt look to have enough room if i was to move the standard calipers out with the provided brackets
  Clio Williams 1, 182,197
Yer im running 285mm discs with 4 pots !! With standard Willy wheels.
There is just enough room for the 285s with 4 pots. No rubbing and they are awesome brakes !! Well impressed with em !!
Oh and Raiderman,
Yours will fit mate no probs. If i can get 4 pots on then the standard calipers will fit with the adaptor. ;)
  Clio 172 cup
285mm discs will NOT go on a williams with the standard calipers
Rally Design no longer do the big brake kit for the williams \ 16v because of this
Quote: Originally posted by adiclio16v on 31 August 2003
i think k-tec an bb use hi-spec for there 4-pot conversions i was thinking of theses when i got the cash
adi
Yeah, they both use hi-spec. You can also get them direct from http://www.hispecmotorsport.co.ukwww.hispecmotorsport.co.uk I have a set of 4 pot calipers and 285mm discs on order from them - should be here next week.
