Big problem
Car  Mk2 Ph2
Last night i was out and my tyre literally burst (front wheel), but was because the inside of the tyre was rubbing against the front coilover adjusting ring lol ( the thing that makes the coilys adjustable) anyway, wat do i need to fix? spacers? if so how many mm?
Spacers will cure it. Although how much you need depends on clearance issues!
10mm would probably cure it. Although make sure you only buy hubcentrics.
Could also sort it by adjusting the front camber. If you have it negatively cambered quite a bit then that could cause this, or spacers is another option.
a recently got that all sorted camber set etc but tis does seem to have changed and face inwards a bit,
anywhere i can get them on the cheap? not looking for looks or performance etc just to stop tyres hitting the coily lol not want to spend a lot tbh :)
