Bigger Brakes
J
jackthelad
Could anyone please tell me if its possible to fir brakes from a 2.0L clio to a 1.6 16v clio (54 reg). and if you know, how hard is it?
shouldnt see why not.. probs a lil mod will have to be done.. im not really up together on Brakes thou!!
Yes and no you caould do it but the 182 brakes arn't necessary ds2500 pads new fluid and lines is more than enough.
If you want real stopping power get some 4 pots plus they look better. You'll never need them with a 1.6 though unless its highly tunned.
for my 04 plate 1.4 16v. Im gettin brembo max disks, ds2500 pads, braded lines for clios with rear drums!! and dot 4 fluid. Should stop nicely after that! pretty much the same set up people go for on the 182 just no brembo high carbon disks.
Cheerz guys, but how do i go about getting what i want and where do i get it from?
What do you want a 2.0 Clio setup?
The stock setup with better fluid and new braided lines ds2500 is superb I use cheap Halfords OE pads, stock disks, stock lines and Superb dot 4 fluid without any trouble on track the Mk2 2 Clios brakes (along with the 1.6 16v Mk2 phase 1) have the same as Williams which had 150hp so as you can tell there a little overpowered.
