oh well thats a different story altogether. I would expect even piper 285 cams to be on the mild side (borderline as they're pretty decent) for that bottom end.
The reality is, you've not going to see more than 175bhp with standard injectors due to their size, (they're actually maxed at 168bhp I believe i calculated a while back) with proper management well mapped, correctly dialed in cams, and larger injectors, you're looking at getting close to 200bhp with a high compression bottom end, but adding ITBs will get you to the 215/220 bhp area and with a load more torque and a much better power spread. Cam choice is fairly key to end results at this level
