Bilstein B14 Coilovers - top mounts
Do they need specific top mounts?
I understand that they can run with OE top mounts but if going for PMS top mounts then they need to be specific :S
Eventually i want to go for PMS top mounts and strut brace but it wont be till a while after getting the coilovers, is this going to be an issue?
I ran my B14's with pattern Bilstein top mounts, a replacement for OE.
The PMS Bilstein specific top mounts are only for the competition spec dampers, with B14 you can run the normal PMS top mount setup IIRC.
Ahh ok so the PMS Bilstein specific top mounts are for something different to the b14. That makes sense.
I asked them and they said they are those fitted to Clio Cup cars, but if buying their standard mounts for B14s they give you the washer
