bit of valver help if you will.........
Car  Vee dub
Haven't driven my car for 5 days or so....
It won't start at the moment... thought it was the battery at first... but when I go to start it up there is a sort of electric ticking sound quite loud... and then nothing happens
any of you lot know what it could be?
Tom
Could still be battery mate, ive had one before that was flat enough not to kick in the starter motor but it still try'd to engage the solenoid... hence the ticking sound.
Check the battery if ya can mate, par that get the charger out ;)
If its a single click when you try and start it its your starter motor mate ;) either flick the key in the ignition or whack the starter motor! Hopefully its just a flat battery thou
starter motor doesn't click atall if the solinoid is stuck, nothing happens, if the solinoid is stuck then its not gonna click, even once :P
yeah its battery fella
can't wait to get out and drive the thing!
Mine makes kind of a tick/click noise when you turn the key the 3rd time! And it def the starter motor :(
