Bleeding Brakes
JamesBryan
Does anyone know the diameter of silicon hose required to fit on the bleed nipple?
and also, will 1 litre of fluid be enough to flush and replace the current fluid?
  182 Trophy #333
According to autodata 1.7 litres required for 2.0 clios fitted with ABS, i used about 1.5litres when i changed mine irrc
  clio 182 sport
Yeah that's why i've got it tbh, and i've heard it's pretty good.
I'll be using it through one of those pressurised bleeding kits, so it should be simple... he says lol
All you need is a spanner, bit of pipe and bottle and a friend lol it is simple.
LiamR172
Scotland - NW
Had mine done last night and it used 1 full bottle and roughly 3/4s of the second bottle. 500ml bottles so probs about 900ml total used at most
172 with abs if it makes a difference!
MRBILLYUK
  FF Jeden Osiem Dwa
Don't even need a friend . Just a length of tube , spanner and a bottle ( with some old brake fluid in if you have any ) . Keep the end of the tube under the surface of the brake fluid so it can't suck any air back , pump the brakes a few times , check fluid level , top up , so on and so forth . Piece of piss , init ;)
