bleeding rear brakes
when bleeding the rear brakes is it a simple case of removing wheels and using a method to bleed or does pressure need to be applied to the axle beam?
  TVR Cerbera
i bleed mine with the car on the ground, not hard to get to.
i would have thought you would need weight on the wheels for the bias valve, but not sure.
Thats what I was wondering about, the bias valve and weight on it. not to worry then. should be up in the air on ramps so should make it easier to get to.
cheers mate:)
