blowers not working....
Car  clio 16v
the blowers on the misses RT have stopped working, still gets hot, just doesnt push the air out. Fuse has not blown, so is the next step to change the relay? Ive been told this is under the scuttle board? is this correct, and is it an easy job to do? Does any one know the part number so i can get one from Reno, or is any1 breaking an RT (will a valver one fit?) that i can have??
You need to check the actual plug on the back on the control panel as these often burn out, next stop would be the dropper resistor which is attached to the blower motor under the scuttle panel.
There is no Relay!
If you need any bits i can supply them.
Mat.
matt, have checked the switch behind the control panal, all seems ok, how much labour is involved in changing the resistor?
If you have skinny hands you can just about reach it with the scuttle panel in place but to make it easier i would remove it.
Once that is out of the way it is nice and easy, just take the plug out (worth just trying some WD40 in this first) then its 2 screws i think.
Mat.
