Ok so I fixed the leak today which I thought would sort my low mpg but it hasn't, I'm getting about 28mpg average.. What can I do to make this better? It's only a 1.2!
If it is out quite a bit then yeah it would affect it aswell as tyre/suspension wear etc. and its best to pop it into a garage to get it laser alligned. Usually takes an hour tops.
I take it your computer says you get 28mpg. How many miles can you get out a tenner or so? Computer readings might be knackered
I'm not sure exactly how many miles I get but I will check, I can safely say it isn't a lot though, I filled up a whole tank last week and did maybe 300 miles if that..
Is there anything else other than wheel alignment that could cause it? Seems to run ok too.
