blue parrot ck3100 easy to install?
Car  Clio 182 Trophy
Found a 2nd hand one on ebay. Could really do with a decent handsfree for work. only thing is im awful with wiring! Advice needed on a decent handsfree thats easy to install, plug and play on a 182 trophy Thanks Luke
There usually just plug and play with the iso blocks. the tricky bit is tucking the wires away. its probably a top of the dash off job.
P.S your picture is upside down.
I've got one.
I removed the radio, and fed the wires in through the side of the center console via the steering column. My blue box and wiring loom is velcro'd inside the steering cowl and my display unit runs up the inside and is stuck to the top of the steering cowl in the center. IMO it is the tidiest way to install them. I can get a picture if you want?
I've got one.
If you could grab a picture that would be great!
Luke
