Quite a few bits done over the past week. First off was refitting the rear beam and LSD with polybushes...
After a bit of effort/balancing act on a jack everything was bolted up in position..
Next thing was I wanted to grind all the brackets out of the engine bay that were no longer needed..
Now I had to crack on with a job I had been putting off for a while. I needed to move the servo over as far as possible (so its further away from the turbo/manifold). Its in the same place on all E30s, just the RHD models have a bar behind the dash that links the pedal to it.
I am using a (Clio) 182 master cylinder and servo with it having a good sized piston, so started by holding it in position to see how much room there was to play with..
There was a good 40-45mm available, so I removed the pedal box to see how that was set up..
The 'fork' on the servo usually goes around the piece that sticks out with a pin through it.
The furthest over I could go was around 40mm, so the fork of the servo would be inside the pedal like it is on a Clio. Out came the grinder..
..and then started measuring up. Its only possible to remove the back plate and not the side, as the clutch master cylinder bolts to the side of the pedal box so that had to remain where it was. I could
just get 40mm out of it before the servo hit the metal on the side of the pedal box. Used some 3mm plate and marked it up so the servo would fit perfectly up against the side of the pedal box frame..
Then welded it back onto the pedal box itself in the correct position (as far over as it would go)..
Obviously this would not line up with the holes in the bulkhead on the car, so I got chopping. Before:
After:
..and roughly got the 'new' pedal box in the correct position..
From that I cut some 1.5mm plate slightly over sized with the holes in the right position for the new pedal box. After lots of trimming with a sanding disc I got it sat inside the hole pretty well and tacked it in..
Happy with the position it was welded solid from the engine bay side. Couldn't get a good picture so took one from inside..
Pedal box bolted up fully in the correct position and everything lined up really well..
The servo was then bolted on to check fitment, along with the master cylinder..
Much further over when compared with the original picture further up and should give me a lot more room to play with! The pedal just needed drilling through to accept a bolt for the servo fork to finish it off..
Lastly I sanded the engine bay down quickly and gave it a freshen up with some black spray. I will eventually get the whole car properly done once its caged (a lot of the body work is flat), but that's something for the future!
Another one of the 'big' jobs out of the way, so going to get the engine back in this weekend and go from there!
