Bolt trouble
Right. Do I have one bolt off the plastic bit for the rear seats and the other is so stubborn that it's worn away the top of the bolt so I can't use a socket anymore. How can I get this off?
Also the t40 holding the drivers seat belt in to get the door cards off won't move and has worn away inside. Passenger one came off fine.
Hit a wall with this and need it sorted asap,
Amy light?
For the metal bracket between the split on the rear seats, one bolt comes out and the other just loosens so you can slide the bracket out. I had trouble with the one that comes out so used lots of wd40 and mole grips and lots of time.
Drivers seatbelt side I used a socket instead of torx.
All sorted, hammered the torx in and it came out and for the rear seat used a spanner torx to loosen the bolt to slide them out :D
I hacksawed the rear bolt head off when the torx head rounded, then slid the seat off. The stud that was left, I fitted a nut to, tack welded it to the stud and unscrewed using a normal socket and breaker bar.
