Bonnet washer jet removal
Car  RB 182
I'm trying to get the drivers side washer jet off my bonnet to replace it and was hoping someone could tell me how it comes off. Didn't want to force it it its screwed in. Many thanks in advance. :D
take the hose off from under the bonnet and then get a screwdriver and push it through, it'll pop out easily enough.
it will have a plastic spring that bends when you push it one way. just carefully use a flat headed screwdriver to push it in and itll drop out.
when putting them back in, if the pipe is hard to push over the nipple, heat the pipe up with a lighter, itll soften it, then itll go on easy
