Braided Hoses
  Clio 200 Black and White
My trophy's brakes fade pretty badly whenever I get on track, so I'd like to upgrade to braided hoses.
Thing is, I can't quite see where to fit them. Do you remove the hard pipe and rubber hose that connects into the calipers front and rear and use the braided hose instead?
As far as I can tell, there are other sections of the brake lines that have rubber hoses in them, can these be replaced with braided hoses as well?
  Lionel Richie
you just replace the flexi hoses that connect the hard lines to the calipers (ie the flexi bridges the gap) for the front
both rear flexi's are on the passenger side just in front/above the rear beam
on my car the calipers at the front have a hard line going into them, do I replace that hard line section as well? There doesn't seem to be a screw connection from the hard line to the rubber hose.
So at the rear, the lines connecting to the calipers actually remain rubber, is there no way to change those as well?
