Brake bleeding kits
Waitey
  Alpina D3, AC Cobra
Which kits do you guys use? My old ezbleed kit has cracked, so looking for a new one.
Sealey any good?
Short Norman
  997 C4S
what's the trick to getting the brake pedal to work with little or no travel.
My M3 has just had a load of work done, and one item was braided lines. After picking the car up the brake pedal now feels like it has an inch or so of travel before there's any bite. Before there was no travel at all.
The specialist I took it to isn't local so I want to try and sort it myself (also got the same issue on one of her cars so I'd like to sort that to.).
Mr Trailer Man
Use one of the bleeders mentioned in here and pump the pedal at the same time.
Should get a rock solid pedal then.
Failing that, do as Dave says. Although there shouldn't be any air in the pump from just changing to braided lines.
Yarp
  Clio 182, E46 M3
I’ve got a pressure one from Halfords I’ve had for years but it isn’t on their website that I can see.
It works well but it’s a f**k on having to connect to a tyre for pressure. I’d probably go with a suction type one if ever I needed to replace.
SharpyClio
That does sound rubbish, the one I have you just pump the pressure up and it does the rest. its mega easy.
Mr Trailer Man
That's the EZ Bleed type.
GiT
  Shit little Yaris...
You may laugh, but I've done 5 or 6 cars with this now and all bled up perfectly. Swapped out a caliper on the Shed (i30) couple of weekends ago - faultless.
