Brake disc diameter on a 1.2?
Car  Black Clio 1.182
Need new front brake discs and pads for my 1.2, been looking on ebay and some listings say disc diameter 238mm and others 258mm :S
I tried researching it but couldnt find much, I did read somewhere though that if your car has ABS then you need 258mm and if not 238mm. My car does have ABS so i'm guessing I should get the 258mm, just want a bit of clarification before I buy.
Easy enought to tell take the wheell off and measure.
If its a pohase 2 most likly will be a 259mm disks only some early 1.2 8v have the smaller ones from memoery
