Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
hit it HARD with a hammer on the front, on the hub bit as that's where it's sticking. 3 or 4 good hits there, then start knocking it off from behind and it should come easy
Just hammer it. If its absolutely proper stuck angle grind a 1" slit into it and smack a cold chissel down it. The disc will split all the way across the hub then just lift off.
My driver's side one was well-stuck on when changing discs last week.
Mate couldnt get it to budge at all so the club hammer + "stand back" worked a treat!
