brake discs
Car  Audi A4
Hi
I've just been looking on the gsf website, but I can't seem to find the brake discs for a mk1 172
Can anyone give me the code
Also anyone recommend a good combination for all braking parts for the front and rear of the car
Try Yozzasport package (with the DS2500):-
199 delivered includes disc pads and hoses..Oh get your fluid upgraded (if you track it) or at least fresh fluid in there and give them a good bleed.
what fluids do people recommend?
is that price for front and rear brake discs and pads, also is that a racing setup because I don't use tracks only the road, so would it be necessary
thanks
German & Swedish,
The MK1 172 Vented ones are R62339 (Fronts) - £25
Dunno the Rears, best bets probably ringing them up mate - 020 8917 3802
--Tom
The rears are expensive probably worth seeing if Yozzasport do them cheaper. The front are 280mm.
£60 for nw front disks delivered if you shop around for stock disks and Renault pads are £40 or so which are fine unless you've had fade issues.
thanks
Fronts only and DS2500 are fast road pads and will be a vast improvement over standard. But get some good fluid and bleed the brakes properly.
The Yozza kit with P&P included is as cheep as anywhere.... I have the same set-up and for the road this is your best set-up.
Rear discs with bearings & abs ring - renault part are £150 inc delivery. rear pads are available ranging from £25 to £125
/y0z
Tom RT said:
German & Swedish,
--Tom
£25 each, + VAT & delivery from gsf. ;-)
/y0z
