tommyc said:what fluids do people recommend?
is that price for front and rear brake discs and pads, also is that a racing setup because I don't use tracks only the road, so would it be necessary
thanks
edde said:The rears are expensive probably worth seeing if Yozzasport do them cheaper. The front are 280mm.
£60 for nw front disks delivered if you shop around for stock disks and Renault pads are £40 or so which are fine unless you've had fade issues.
Tom RT said:German & Swedish,
The MK1 172 Vented ones are R62339 (Fronts) - £25
Dunno the Rears, best bets probably ringing them up mate - 020 8917 3802
--Tom
