Brake Ducts - Version 2
Car  Turbo Beige
After the originals i fitted where a bit large, and then the wire in the CAF went rusty after 10 days, i removed them and got a refund ( http://www.cliosport.net/forum/showthread.php?t=201262&highlight=brake+ducts ).
I made up some new ones smaller and they fit the foglight hole perfectly. They were also cheaper than the originals, and a LOT cheaper than the cup racer versions!!!
There is nothing in these that will rust and they look a lot better. The only thing i have an issue with is fitting the inlet to the plastic foglight surround (its done with double-sided sticky foam padding at the moment), its not quite sitting right, so im going to look at mounting them in a different way.
Gaffa tape, cable ties, double sided sticky tape! Thats gonna out last the rest of the car! :clown:
Good mod fella :approve:
Nothing like good solid mods!!!!
Ali
My discs were already used and heat cycled, so i only had to do the pads. This is just a precaution, i did the original ones with the standard brakes to try and help the fade issues.
I want one, what size cone did you use/make, also nice solid white wheel lol
