Brake fluid for track days that isnt Super Blue?
Car  Ph2 Clio 172
What's a good fluid for track days? I got some more Super Blue to replace what I already have, but have realised its going to be a pain to change blue fluid with blue fluid as I won't know when its cone through. What other suggestions are there for affordable track day fluid?
The thing is it will mix in the resivoir anyway so its going to be hard to tell when the new fluid is going through, by the time it starts running clear you will have used the same if not more fluid as you would of used just pumping a good 250ml out each caliper.
Just give all the calipers a good bleed untill the pedal is nice and firm again!
If the fluid isnt that old then you might not notice a difference in colour!
The fluids not old but its done enough track days to be screwed so it might have a different colour. The syringe idea is a good one, cheers.
I've got plenty of time to sort it (all winter) so I think I might just give it a try with the Super Blue I have and if I struggle ill get something else.
What's the best oder to do them in? Rears first then passenger front then drivers?
