Brake Hoses - Fitting
One night this week I am going to replace my 182 brake hoses for some Goodridge ones (thanks Fred & Yozza:)). Through reading the guides on the forum I think I have a cunning plan, but a question I have is once the hoses are on is there a bleed order for the brakes?
Any other tips would be welcome.
Cheers all :D
The correct order when doing a full system bleed is :
Left hand front
Right hand front
Left hand rear
Right hand rear
But to be honest i don't really see this as being that important as long as all the air has been expelled from the system .
The size of spanner to remove the brake line from the caliper is 9/16 so i would get myself the correct size spanner , i don't like using adjustables cos they can tend to round the nut off if its tight getting it out .
Left hand front
Right hand front
Left hand rear
Right hand rear
That is misinformation
[FONT=verdana, geneva, helvetica]On a FWD vehicle with a diagonally-split brake system, do the right rear then left front brake, followed by the left rear and right front brake.
[/FONT]
I don’t see the need either, but its how it’s done at specialist brake centers, so their must be a reason, however tiny and to be honest, it makes no difference to me time wise any order I do it in.
[/FONT]
I still think i'm right , sorry mate :
Left hand front
Right hand front
Left hand rear
Right hand rear
Thats if the car has abs , just looked in 4 different haynes manuals , thats the way i've always done it . But at least we both agree as long as the air is expelled from the system it should be fine either way .
You are proberly right actually, i have never had abs before, got a cup and a 10 year old rsi, none of which have abs, didnt think it would be different, my mistake.
it doesn't matter what order you bleed the brakes so long as you bleed them properly ie let the fluid come out for some time.
