Basically I have to press the brakes fairly hard to activate the brake lights.
I've had a look at the pedal and the switch and can't see whether I can adjust anything to make it more sensitive.
I have taken the switch out completly and the lights stay on all the time, when you push the switch in it goes out as it should.
My question is do I need to adjust the switch or the pedal alignment? if so how?
Thanks, much appreciated
