Brake line replacement (copper lines - not flexis)
Car  Clio 172 cup
No results from searching this topic..
I'm looking to replace the copper lines from the master cylinder to the flexis. They run between the bulkhead and the heatshield and there's very little room behind the engine. Just going on the amount of space available, it appears to be an engine out job. Is this the case? Has anyone found a way of replacing the brake lines with the engine in?
Cheers for your thoughts.
Peter
