brake load regulator
Car  valver
hi, has anyone ever had to replace, or ideally fix, their brake bias load regulator valve, on a valver? need to look at it tomora to pass mot, just wondering what the problem is? do they seize, need adjusting or simply just need replacing? any info greatly received, cheers ben.
Yeah they seize mate, on the back axle so as you can imagine, salty water, and just general s**t.
As per Sami's link or easy fix is soak it in lubricant, work it up and down with some pliers, soak it, work it, keep going till its free. Don't be tight with the WD40 soak the lot.
