Golf GTD Mk7
Been getting some wierd noise coming from the brakes in the past few months under heavy braking. Its hard to explain, but it sounds like a 'wowowowowowowowow' noise :S. It seems to have done it since I did bedford, but 5 months on and its no changed. Brakes have been pressure bled since also, but no change. The braking isn't as sharp and feels less responsive. I usually put some heat through them before any hard braking anyway. Once it has made this noise, the pads seem to grip fine. But should they be doing this? ABS isn't kicking in, its as if they are slipping on the discs. Any ideas? Could they be glazed over? There is still plent left on both discs and pads.
