clio 172
Car has been standing for years , I installed goodridge lines up front but had them off for a week.
tried 2 man method originally with no success .
Ive got the ABS Bleed software so ive attempted bleeding from the pump at each caliper , pedal is quite hard with igniton off.
As soon as you fire up the car , the pedal just goes straight to the floor.
I was going to see if I can get a friend round to try do a 2 man manual pump now ive had the valves open with the software.
would this happen if master cylinder was knackered or would you not get any pressure in the pedal with ignition off ?
I don't fancy paying £200 for a master cylinder and still having the issue .
ive searched on here and a lot have had the issue but had different solutions .
